J Mack Posted April 13, 2021 Share Posted April 13, 2021 On 11/14/2016 at 4:40 AM, cedric34310 said: salut Maxime, pour l implantation , selon l utilisation ce sera différent pour uniquement du saw avec le gouv dans l axe , il faut augmenter la trainée du safran et de mémoire j avais 100 ou 120gr de + coté gauche j avais choisi cette opts car il y avait la cavalerie sous le capot !!!! sinon et si je devais m en refaire un , je mettrais 2 petits safrans avec un 1530 Viper qui permettraient une utilisation multiple ........ Cedric34310, I am ordering parts for my Micro Drifter and would like to ask if in 2021 you would still follow this two small rudder idea that you talk about here in 2016? If you still think two is better than one could you give me ideal demission's for the rudders? My plan is to order parts and make the style rudder you made here for Maskali XIII SAW so I should be able to make any size you think is best. Thank you very much! Link to comment Share on other sites More sharing options...
cedric34310 Posted April 13, 2021 Share Posted April 13, 2021 @J Mack, salut ce micro drifter sera pour faire de la vitesse uniquement ? Link to comment Share on other sites More sharing options...
J Mack Posted April 13, 2021 Author Share Posted April 13, 2021 @cedric34310 This boat will mostly be for having fun and learning about the differences of boat setup, I don't know about a body of smooth water right now that is long enough to test top speed safely so for now I will setup for making turns in both directions and maybe look into speed only later. Thank you! Link to comment Share on other sites More sharing options...
cedric34310 Posted April 13, 2021 Share Posted April 13, 2021 c est pas évident de te conseillé sans que tu es des modifications a faire a l avenir. un montage ne peut pas forcement faire plusieurs utilisation , les équilibres longitudinaux et latéraux changent selon la vitesse, l hélice utilisé et pleins d autres paramètres. pour une première utilisation, tu peux faire simple avec hélice et gouvernail dans l axe de la coque ........ ça te permettra de te faire la main et comprendre certaines choses. 1 Link to comment Share on other sites More sharing options...
J Mack Posted April 13, 2021 Author Share Posted April 13, 2021 Thank you Cedric34310, I have ordered several motors, batteries, controllers, propellers, drives and rudders to look at, most of them are the same or very similar the parts you used on your drifter build or as close as I could find without asking you to advise every part. Everything is coming from Germany or China and I have a very long wait time to get here in the USA but once I have everything here maybe you could advise a good starting point with parts on hand or make suggestion for replacement parts before I start cutting and gluing. I don’t mind to put the parts in a drawer and buy all new parts if I can do it right the first time it is better for me than try to use a part that is not correct. Link to comment Share on other sites More sharing options...
cedric34310 Posted April 13, 2021 Share Posted April 13, 2021 oui pas de soucis tu as des photos des pièces ou liens ? Link to comment Share on other sites More sharing options...
J Mack Posted April 13, 2021 Author Share Posted April 13, 2021 I know I’ve ordered some other random stuff to try to have a few options of parts here at my work shop but this is the recent list from My CC Company for stuff I have ordered in the last two weeks. ETTI Online order 2 x Aluminum Alloy M3 Cap Screw Washer (10 pcs) 1 x M4 Threaded Security Collar for 4mm stub shaft (Pack for 5 pcs 2 x Light Weight Strut c/w two ball bearings (Anodized Blue / 45mm h 2 x Aluminum Alloy M4 Cap Screw Washer (10 pcs) 2 x Light-weight Anodized Blue Antenna Holder 2 x Ultra Low Resistance 3.5mm Gold Plug (Pack for 3 pairs) 1 x Coupler 4mm/3.2mm (.130") 1 x Integrated Motor Coupler 4mm to 1.4mm & 3.2mm(.130) 2 x M4 Prop Shaft for 2mm piano wire (70mm) 1 x M4 Threaded Drive Dog c/w Brass End for 3/16" Prop 2 x M4 prop shaft for .130(3.2mm) flex cable (70mm long) Tenshock, VZ-1515 BRUSHLESS Motor TS-2925-SLT Motor Jacket New BX40 MARINE BRUSHLESS Electronic Controller Steering Assembly for 06015D Rudder (Qty 2) Controller Function PROGRAM CARD TS-11020D 110mm Carbon Rudder CNC PROPELLER TS-PSP-C4834/3-A (Qty 2) CNC PROPELLER TS-PSP-C5036/3-A Colorful Waterproof (Qty 4) Set Mini Mono Boat Mini Fin Assembly (Qty 2) CNC PROPELLER TS-PSP-C4632-A CNC PROPELLER TS-PSP-C4834-A TS-06015D 60MM RUDDER CNC PROPELLER TS-PSP-C4330-A Banggood, 1PC 29mm Silicone Water Cooling Jacket for 540/3650/3660/3674 RC Boat Marine Motor 1PC 29mm Silicone Water Cooling Jacket for 540/3650/3660/3674 RC... US$4.00 x 1 Color1:Blue 1PC 29mm Silicone Water Cooling Jacket for 540/3650/3660/3674 RC Boat Marine Motor 1PC 29mm Silicone Water Cooling Jacket for 540/3650/3660/3674 RC... Color1:Black Racerstar 2845 Motor Brushless Waterproof Sensorless 5900/4370/3930/2800KV 1/12 1/14 RC Car Part Racerstar 2845 Motor Brushless Waterproof Sensorless... KV:3800KV B20/B24/B28/B36 RC Motor Water Cooling For RC Boat B20/B24/B28/B36 RC Motor Water Cooling For RC Boat Type:B28 Surpass Hobby 2845 KK Series 2-3S Brushless Waterproof Motor 5900/5000/4400/3800/3100/2800KV for 1/12 Rc Car Surpass Hobby 2845 KK Series 2-3S Brushless Waterproof Motor... KV:3800KV Hydro & Marine Drifter Micro WE CFK Special Edition Micro Offshore Catamaran*** Ersatzflexwelle 3,2 mit 5 mm Welle und M4 Gewinde Teflon tube 4 / 5 for 3.2 Flex length 500 mm Midi-Wedgerudder 110 w. Watercooling system Propeller JR C-Serie 30 mm Dreiblatt Propeller JR C-Serie 33 mm Servohalter Universal GfK Spannzange H&M 5 / 3,2 NEUE Generation Flex Hex / Collet H&M 1/4-28 UNF / 3,2 Flexcable NEW Generation*** Teflonmetallager 5/7/10 Gear-Flon 20 g Teflongrease Thrust nut 10 mm with M4 thread - New version brass / chromed Bellows cylindrical Elastic rubber bellows H&M SUPER masking tape STANDARD 25 mm 20 meter Flex system II 3.2 / 5 / M4 B short strut Complete flex system Cable direction: Regular RIGHT Lunsford racing 4mm Titanium Cap Head Screws × 2 4mm x 12mm (4pcs) 3mm Titanium Custom Pan Head Screws × 2 3mm x 15mm (4pcs) 3mm Titanium Cap Head Screws × 2 3mm x 20mm (4pcs) 3mm Titanium Cap Head Screws × 2 3mm x 10mm (4pcs) 3mm x 7mm Titanium Brushless Motor Screws (2pcs) × 2 Then from random sellers, Leopard 2850 X2 Motor 3330 Kv/rpm per volt 4D : 4mm shaft FS Flysky RC Noble FS-NB4 Remote Controller Radio Transmitter for Rc Car/Truck/Boat w/ FGr4P Receiver, Transmitter Battery Flycolor 90A 2-6S Waterproof Brushless ESC Speed And Programme Card Flysky FS-CPD01 FS-CPD02 FS-CTM01 FS-CEV04 FS-CVT01 Temperature Collection Module For iA6B iA10B Receiver FPV Racing Drone Item #8128790272834613 Flysky FS-CPD01 FS-CPD02 FS-CTM01 FS-CEV04 FS-CVT01 Temperature Collection Module For iA6B iA10B Receiver FPV Racing Drone Item #8128790272844613 Flysky FS-CPD01 FS-CPD02 FS-CTM01 FS-CEV04 FS-CVT01 Temperature Collection Module For iA6B iA10B Receiver FPV Racing Drone Item #8128790272854613 Flysky FS-CPD01 FS-CPD02 FS-CTM01 FS-CEV04 FS-CVT01 Temperature Collection Module For iA6B iA10B Receiver FPV Racing Drone Item #8128790272864613 Turnigy Graphene Panther 2200mAh 3S 75C Battery Pack 9067000371-0 Power HD 1810MG Metal Gear Brushed Digital Servo 21T 3.9kg / 0.13sec / 15.8g 068000016-0 USA HobbyKing 60A (2~4S) ESC 4A SBEC F-60A USA HobbyKing ESC Programming Card 9261000016 USA IC-2000 Rubber-Toughened CA Adhesive (20g Tube) 9117000008-0 USA 4mm Easy Solder Gold Connectors (10 Pairs) 2PC RoaringTop LiPo Battery Pack 100C 1300mAh 4S 14.8V with XT60 Plug for RC Car Boat Truck Heli Airplane 2PC RoaringTop LiPo Battery Pack 100C 1300mAh 3S 11.1V with XT60 Plug for RC Car Boat Truck Heli Airplane If you have suggestion I will get it ordered and add to this list. Link to comment Share on other sites More sharing options...
cedric34310 Posted April 14, 2021 Share Posted April 14, 2021 salut, tu as fait un jolie petit stock ! je suppose qu il y a une partie pour le mini mono tenshock ......... pour le micro drifter je vois quelques éléments électriques qui iront pas trop mal : Racerstar 2845 moteur sans balais étanche sans capteur KV: 3800KV HobbyKing 60A (2 ~ 4S) ESC 4A SBEC Batterie Turnigy Graphene Panther 2200mAh 3S 75C HÉLICE CNC TS-PSP-C4834 / 3-A (Qté 2) HÉLICE CNC TS-PSP-C5036 / 3-A HÉLICE CNC TS-PSP-C4632-A HÉLICE CNC TS-PSP-C4834-A Power HD 1810MG Metal Gear Brushed Digital Servo 21T 3.9kg / 0.13sec / 15.8g le esc est limite et tu devras lui ajouter un refroidissement. la programmation du neutre risque aussi de te posé quelques souci, un pistix sera surement nécessaire. 1 Link to comment Share on other sites More sharing options...
J Mack Posted April 14, 2021 Author Share Posted April 14, 2021 If I do single rudder can you tell me if the dimensions on this drawing are appropriate? Link to comment Share on other sites More sharing options...
brushman Posted April 14, 2021 Share Posted April 14, 2021 Hello, Cedric, if you don't mind... I think the Pistix is not needed , this Noble transmitter has a throttle boat mode where the brake travel course is removed in favour of an "extended" throttle curve. 6.15 in the user manual. the servo could be from the same brand, but HD TR-4, it a waterproof version. 1 1 Link to comment Share on other sites More sharing options...
J Mack Posted April 14, 2021 Author Share Posted April 14, 2021 2 hours ago, brushman said: the servo could be from the same brand, but HD TR-4, it a waterproof version Thank you @brushman I just ordered two HD TR-4 waterproof servos to add to my pile of parts. Link to comment Share on other sites More sharing options...
ketokole Posted April 14, 2021 Share Posted April 14, 2021 Hi It was the dimensions on mine...I agree my sketch Hydro&marine sold all the transmission (flex + rudder + strut) in 2013/2014 2 2 Link to comment Share on other sites More sharing options...
cedric34310 Posted April 14, 2021 Share Posted April 14, 2021 sur le principe je suis ok mais le safran est trop loin derrière l hélice. il faut que le bas du safran soit dans l alignement rouge 1 1 Link to comment Share on other sites More sharing options...
J Mack Posted April 14, 2021 Author Share Posted April 14, 2021 5 minutes ago, ketokole said: It was the dimensions on mine...I agree my sketch Hydro&marine sold all the transmission (flex + rudder + strut) in 2013/2014 Thank you @ketokole I could not remember how I found the sketch but I kept a copy for my records. Hydro&Marine told me they can make no recommendations and don't sell the proper hardware at this time so my plan is to copy the @cedric34310 carbon fiber style hardware to the proper dimensions and I will follow your sketch. 3 minutes ago, cedric34310 said: sur le principe je suis ok mais le safran est trop loin derrière l hélice. il faut que le bas du safran soit dans l alignement rouge Easy to make the adjustment to drawing now if you tell me move rudder forward or propeller back to make closer. 1 1 Link to comment Share on other sites More sharing options...
cedric34310 Posted April 14, 2021 Share Posted April 14, 2021 l hélice est déjà éloigné donc il vaut mieux rapproché le safran 1 Link to comment Share on other sites More sharing options...
J Mack Posted April 14, 2021 Author Share Posted April 14, 2021 I will add note to drawing on my side and make adjustment once I get more parts here at the work shop. Can you tell me the proper thickness for rudder material to make behind the propeller rudder? I read you make them thicker to run in this position but I cant find anywhere you say how thick. Thank you for taking the time to answer all my beginner questions. Link to comment Share on other sites More sharing options...
Maskali XIII Posted April 14, 2021 Share Posted April 14, 2021 La règle à mon avis pour un gouvernail, c'est d'être le plus fin et rigide possible... Lame inox ou carbone comme l'a bien démontré notre ami cedric... Il faut avoir en tête que le gouvernail est une vraie enclume derrière le bateau, cela peut-être un effet bénéfique pour la stabilité du bateau, surtout en virages, mais pour la ligne droite c'est moins bon d'avoir une lame épaisse... Link to comment Share on other sites More sharing options...
J Mack Posted April 14, 2021 Author Share Posted April 14, 2021 I appreciate @Maskali XIII but without the knowledge of small RC boat I must rely on you experts to give me some exact detail so I can make the correct part the first time. I believe I read the guys want the rudder a little bit thicker and the trailing edge to be flat with the leading edge sharp when running behind the propeller. Would 3mm or 4mm thickness material be appropriate for this? Link to comment Share on other sites More sharing options...
cedric34310 Posted April 14, 2021 Share Posted April 14, 2021 mes lames carbones font 2mm d épaisseur 2 Link to comment Share on other sites More sharing options...
brushman Posted April 14, 2021 Share Posted April 14, 2021 il y a une heure, J Mack a dit : I appreciate @Maskali XIII but without the knowledge of small RC boat I must rely on you experts to give me some exact detail so I can make the correct part the first time. I believe I read the guys want the rudder a little bit thicker and the trailing edge to be flat with the leading edge sharp when running behind the propeller. Would 3mm or 4mm thickness material be appropriate for this? C' est étonnant la qualité de traduction de L'anglais vers le français, un traducteur Français/Français ne ferait pas mieux! J'apprécie @Maskali XIII mais sans la connaissance du petit bateau RC je dois compter sur vous les experts pour me donner quelques détails exacts afin que je puisse faire la bonne pièce la première fois. Je crois avoir lu que les gars veulent que le gouvernail soit un peu plus épais et que le bord de fuite soit plat avec le bord d'attaque tranchant lorsqu'il passe derrière l'hélice. Est-ce qu'un matériau de 3 ou 4 mm d'épaisseur serait approprié pour cela ? Traduit avec www.DeepL.com/Translator (version gratuite) 1 Link to comment Share on other sites More sharing options...
J Mack Posted April 14, 2021 Author Share Posted April 14, 2021 2 hours ago, cedric34310 said: mes lames carbones font 2mm d épaisseur HA….. I just checked the workshop and I have 1.5mm and 3.2mm carbon fiber and 1mm and 3.2mm titanium plates but nothing 2mm so I’ll get something ordered. Thank you for you comments. Link to comment Share on other sites More sharing options...
ketokole Posted April 14, 2021 Share Posted April 14, 2021 https://www.banggood.com/fr/search/plaque-fibre-de-carbone.html?from=nav 1 Link to comment Share on other sites More sharing options...
J Mack Posted April 15, 2021 Author Share Posted April 15, 2021 5 hours ago, brushman said: C' est étonnant la qualité de traduction de L'anglais vers le français, un traducteur Français/Français ne ferait pas mieux! Préférez-vous que j'utilise votre traducteur pour poser des questions ici ? Link to comment Share on other sites More sharing options...
jc3m Posted April 15, 2021 Share Posted April 15, 2021 Il y a 9 heures, J Mack a dit : Préférez-vous que j'utilise votre traducteur pour poser des questions ici ? Oh oui 1 Link to comment Share on other sites More sharing options...
J Mack Posted April 15, 2021 Author Share Posted April 15, 2021 OK, j'ai fait un petit test basé sur les informations que vous m'avez données. J'ai commencé avec du matériel sous la main (3 mm) et j'ai fabriqué un appareil pour que ma machine ponce à un angle de 0,5 mm à 2 mm sur le gouvernail de direction. Je pense que cela pourrait être réalisable avec un peu plus de pratique pour fabriquer un gouvernail utilisable. Je peux changer de profil si vous voyez un problème avec cet exemple. Link to comment Share on other sites More sharing options...
