VML Posté(e) 8 mai 2007 Share Posté(e) 8 mai 2007 Aprés un bon taff de tout le monde, voici le résumé!: 3 modéles connu notice du premier: ----------ICI---------- notice du deuxiéme: ----------ICI---------- notice du troisiéme: x = bip T = bip tonalité grave __________= petite pause x __________x __________x __________ Brake On xx __________xx __________xx __________ Brake Off Tx __________Tx __________Tx __________ NiCd/NiMh Txx __________Txx __________Txx __________ LiPo TTx __________TTx __________TTx __________ Soft Startup TTxx __________TTxx __________TTxx __________ Hard Startup TTTx __________TTTx __________TTTx __________ Soft Timing TTTxx __________TTTxx __________TTTxx __________ Hard Timing xxxx __________xxxx __________xxxx __________ Reset to factory settings message original: salut a tous j'en ai acheté un et dur dur de le régler... j'ai trouvé ça: I FINALLY got ahold of a set of instructions for programming the Mystery ESC. I had to retype it as the original was almost illegible. Users Manual (FM 40A, FM 60A, FM 80A, FM 120A) Specifications: Model: FM40A FM60A FM80A FM120A Continuous working current: 40A 60A 80A 120A Weight: 35g 55g 55g 70g Input Voltage: NiMH 6 - 16 Cells Li-ion 2 - 5 Cells BEC Current: No Main Functions 1. Safety mode: the motor won't start no matter what the position of the control stick is when switched on the RC unit. 2. Brake Setting: On/Off (factory setting is off) 3. Three point battery type and low voltage selection. 4. Software reversion of motor turning direction. 5. Low current protection: ignore/reduce power/shut off 6. Temperature protection: reduce power when the temperature reaches 120 degrees C 7. PWM frequency: 8KHZ/16KHZ 8. RPM setting: 20,000rpm/50,000rpm/100,000rpm (60A/80A Only) ESC program procedure Normal Start Up When throttle stick is off, you will hear one Beep for Brake on, or two tones for Brake off. Program When throttle stick is at full power connect battery and switch on and wait for 5 seconds. Setup mode isentered: 1. Brake: If you pull the stick to off within 5 sec Brake will be changed (On ->Off or Off ->On) 2. Battery type: (Voltage Cut-off) Ni-Cad . . . . . 2 Lipos(5.6V) .. .. .. .. .. 3 Lipos(8.4V) ... ... ... ... ... 4 Lipos(11.2V) .... .... .... .... .... 5 Lipos(14V) ..... ..... ..... ..... ..... 3. Rotation Reverse: Reverse motor rotation 5 short musical notes 4. Soft Start: Enable: 5 short musical notes Disable: 5 long musical notes 5. Under Voltage: Ignore: _.. _.. _.. _.. _.. Reduce Power: _. _. _. _. _. Cut Off: ._ ._ ._ ._ ._ 6. Timing: Automatic (7 - 30 Degree) .. .. .. .. .. Soft (7 degrees) .. .. .. .. .. .. .. .. .. .. Hard(22 - 30 Degrees) .. .. .. , .. .. .. , .. .. .. , .. .. .. , .. .. .. 7. Frequency: 8kHz ' ' ' ' ' 16kHz b b b b b ------8------ Restore Default Settings: _____ _____ _____ _____ _____ ------9------ Active rpm control: rpm control off: _._ _._ _._ _._ _._ 20,000 rpm _.._ _.._ _.._ _.._ _.._ 50,000 rpm _..._ _..._ _..._ _..._ _..._ 100,000 rpm _...._ _...._ _...._ _...._ _...._ (60A/80A only) Factory Default Settings: Brake: Off Battery Type: 3 Li-Poly Under Voltage: Reduce Power Soft Start: Enable Timing: Auto Frequency: 8kHz Active RPM Control: Off Notice: 1. Make sure the connections for battery positive/negative are right. Reversing the connection will damage the ESC permanently. 2. Use suitable batteries. Do not exceed the working voltage of the ESC. 3. The company keeps the right to change design, function, or package without notice. 4. Take care in using safely. Incorrect use may cause injury to the body. The company will not be responsible for any damage or loss caused by incorrect operation. Enjoy mais j'ai un peu de mal...j'ai l'impression de jouer au tamagoshi cette façon de programmé marche chez vous ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité ester Posté(e) 8 mai 2007 Share Posté(e) 8 mai 2007 vivi ça marche, mais il faut etre très attentif et c'est vraiment long Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 8 mai 2007 Auteur Share Posté(e) 8 mai 2007 mpffff....j'ai mal au crane ! des heures a écoiuter des bpbipbip... c'est peutétre ma manette qui ne va pas. j'ai essayé avec l'attack mais on dirai que selon la molette de réglage fin a coté du manche, il capte ou capte pas ce que je demande.... ce que j'ai compris: je met le contact... soit 5 secondes en haut--->mode réglage soit 5 secondes en bas---->mode navigation(quand je relache, le moteur démarre) en mode programation, il faut donner des coups de manche rapide ?, long ? en haut en bas ? j'capte plus rien @ester, tu utilisé le mode d'emploi ci dessus ? je suivait le post ou tu en parlait, t'en est content finalement ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité fafa76 Posté(e) 8 mai 2007 Share Posté(e) 8 mai 2007 salut , j'ai eu le meme probleme avec une radio a volant ,,, le neutre est au 3/4 et le neutre n'ai pas en bas ,,, il a falu que je deregle le trim de ma radio ,,, ou acheter une radio a manche sans les resorts de rapel ,,,, finalement je l'ai jete.... FV desoler je sort !!!! Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 8 mai 2007 Auteur Share Posté(e) 8 mai 2007 au pire, j'ai 2 manettes je peux modifier les ressort sur l'attack le pire c'est que en farfouillant, j'ai du le dérégler parce qu'il chauffe vite maintenant et le moteur aussi...j'aurai mis beaucopup de timing que ça m'étonnerai pas... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité ester Posté(e) 8 mai 2007 Share Posté(e) 8 mai 2007 oui je me sert de ce mode d'emploi, on ne change qu'un seul paramètre à la fois, quand un paramètre est changé il faut tout recommencer pour modifier le suivant, c'est un peu....long il faut le refroidir sinon ça mouise mais il marche bien, vu le prix radio à manches avec ressort de rappel en+ chez moi fafa tu l'as pas jeté quand meme? Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 9 mai 2007 Auteur Share Posté(e) 9 mai 2007 fafa tu l'as pas jeté quand meme? +1 alors ce que j'ai cru comprendre : x = bip x- = bip long T = bip tonalité grave __________= petite pause en mode programmation, si on touche a rien il fait ça en boucle: x- __________x- __________x- __________ xx __________xx __________xx __________ Tx __________Tx __________Tx __________ Txx __________Txx __________Txx __________ TTx __________TTx __________TTx __________ TTxx __________TTxx __________TTxx __________ TTTx __________TTTx __________TTTx __________ TTTxx __________TTTxx __________TTTxx __________ xxxx __________xxxx __________xxxx __________ soit 9 séquence différente il faut comprendre ça comme ça? : 1/ x- __________x- __________x- __________ Frein oui/non 2/ xx __________xx __________xx __________ type de batteries 3/ Tx __________Tx __________Tx __________ sens de rotation 4/ Txx __________Txx __________Txx __________ soft start on/off 5/ TTx __________TTx __________TTx __________ under voltage 6/ TTxx __________TTxx __________TTxx __________ timing 7/ TTTx __________TTTx __________TTTx __________ fréquence 8/16khz 8/ TTTxx __________TTTxx __________TTTxx __________Restore Default Settings 9/ xxxx __________xxxx __________xxxx __________Active rpm control et donc si je me trompe pas, la séquence 9 sert a quoi ? erreur dans la notice(le reset aux valeurs d'origine n'avait pas été numéroté , c'est corrigé pendant une séquence si on met le manche en haut ou en bas, ça change le réglage, j'ai essayé avec les freins et ça marche mais comment a t'on les retours pour le reste des réglages ? j'explique: si je comprend bien la notice, a la séquence 6/ TTxx __________TTxx __________TTxx __________ y'a un moment ou je devrai entendre 5 fois 2 "bip" pour le timing automatique ou 9 fois 2 "bip" pour le soft timing.... bah je les entend pas... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité ester Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 t'as oublié le reset aux valeurs d'origine (en 8) chaque "motif" est répété 5 fois donc tu ne peu pas avoir 5 et 9 le mieux c'est de suivre avec un doigt sur le papier les différents menus, et de vérifier en faisant le tour complet que tu as le bon nombre de menus il y a une partie avec une sorte de musique ou on perd facilement le fil Lien vers le commentaire Partager sur d’autres sites More sharing options...
pda75 Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 que cela a l'air compliqué... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité ester Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 et long.... farnchement répéter 5 fois ils ont abusé mais une fois compris le truc (faut bien ramer 2 ou 3 fois) ça va n'est ce pas crapo17 ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 9 mai 2007 Auteur Share Posté(e) 9 mai 2007 chaque "motif" est répété 5 fois donc tu ne peu pas avoir 5 et 9 c'est là que je décroche.... concrétement, si tu veux par exemple changer le timing 1/ tu met le manche en haut 5 secondes... 2/ y'a une petite musique...t'es en mode programmation 3/ c'est parti pour les bip x- __________x- __________x- __________ xx __________xx __________xx __________ Tx __________Tx __________Tx __________ Txx __________Txx __________Txx __________ TTx __________TTx __________TTx __________ 4/celui qui nous intéresse arrive là : TTxx __________TTxx __________TTxx __________ 5/ pendant cette séquence, tu fais quoi t'entend quoi ? n'est ce pas crapo17 ? aparement j'suis pas le seul si j'y arrive, je ferai un topic avec des sons ça pourra aider les prochains ebayeurs Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 9 mai 2007 Auteur Share Posté(e) 9 mai 2007 j'ai trouvé une autre notice en PDF... la premiére a été recopié sur un forum maintenant je comprend ce que tu veux dire par répéter 5 fois... éfféctivement le réglage est toujours répété 5 fois mais quand ? juste aprés le coup de joystick ? si c'est le cas c'est ma manette qui ne va pas... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité ester Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 il faut maintenir a fond tout le temps en mode programmation et tu met en position off (neutre) quand tu est sur l'option que tu veux sélectionner, attention après il faut recommencer a zéro...on ne modifie qu'un seul paramètre à la fois Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 9 mai 2007 Auteur Share Posté(e) 9 mai 2007 ok je commence a y voir plus clair j'essaye cet aprés midi merci ! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Wilfried27 Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 il faut maintenir a fond tout le temps en mode programmation et tu met en position off (neutre) quand tu est sur l'option que tu veux sélectionner, attention après il faut recommencer a zéro...on ne modifie qu'un seul paramètre à la fois ça à l'air d'etre une belle merde ce contro Lien vers le commentaire Partager sur d’autres sites More sharing options...
catmann Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 vive mon usbcom sur mes mgm !!!!! un tableau sur un ecran et hop tout est programmé!!!!! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité ester Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 des contros 80A a 45€ faites moi signe quand vous en trouvez wilfried Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 9 mai 2007 Auteur Share Posté(e) 9 mai 2007 éh bah ... j'en suis toujours au méme point ! catmann Ecrit le 09/05/2007 - 13:29 vive mon usbcom sur mes mgm !!!!! un tableau sur un ecran et hop tout est programmé!!!!! ça à l'air d'etre une belle merde ce contro laugh.gif bah pour 19€50 FDPIN j'peux bien me cramé 2-3 neurones j'ai essayé avec mon autre manette t6exa...bah toujours pareille qu'avec l'attack. le mieux c'est de suivre avec un doigt sur le papier les différents menus, et de vérifier en faisant le tour complet que tu as le bon nombre de menus il y a une partie avec une sorte de musique ou on perd facilement le fil j'ai bien le bon nombres de menu j'ai vérifié et revérifié en plus, si tu fais un tour complet, il fait une pose de plusieurs secondes entre la séquence 9 et le retour a la 1... alors pendant la séquence j'ai tout essayé mais je n'entend pas ce qui est entouré en rouge... le PDF en entier ---->ici<---- alors ce que j'ai entouré en rouge, on l'entend quand ... aprés avoir fait quoi... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Wilfried27 Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 des contros 80A a 45€ faites moi signe quand vous en trouvez wilfried Ouais bah ont ce rend compte pourquoi il ne coupe que ce prix la ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 9 mai 2007 Auteur Share Posté(e) 9 mai 2007 des contros 80A a 45€ faites moi signe quand vous en trouvez wilfried et encors, j'en ai acheté plusieurs...le plus cher a 30 fdpin Lien vers le commentaire Partager sur d’autres sites More sharing options...
catmann Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 CA FAIT CHER LA BOITE A BIP...... OK JE SORS !!!!!!!!!!!!!!!! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité ester Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 des contros 80A a 45€ faites moi signe quand vous en trouvez wilfried Ouais bah ont ce rend compte pourquoi il ne coupe que ce prix la ... écoutes wilfried, je trouves tes commentaires particulièrement déplacés, vu ce que tu connais et les questions que tu poses c'est de la pure polution alors stp abstient toi Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité ester Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 éh bah ... j'en suis toujours au méme point ! catmann Ecrit le 09/05/2007 - 13:29 vive mon usbcom sur mes mgm !!!!! un tableau sur un ecran et hop tout est programmé!!!!! ça à l'air d'etre une belle merde ce contro laugh.gif bah pour 19€50 FDPIN j'peux bien me cramé 2-3 neurones j'ai essayé avec mon autre manette t6exa...bah toujours pareille qu'avec l'attack. le mieux c'est de suivre avec un doigt sur le papier les différents menus, et de vérifier en faisant le tour complet que tu as le bon nombre de menus il y a une partie avec une sorte de musique ou on perd facilement le fil j'ai bien le bon nombres de menu j'ai vérifié et revérifié en plus, si tu fais un tour complet, il fait une pose de plusieurs secondes entre la séquence 9 et le retour a la 1... alors pendant la séquence j'ai tout essayé mais je n'entend pas ce qui est entouré en rouge... le PDF en entier ---->ici<---- alors ce que j'ai entouré en rouge, on l'entend quand ... aprés avoir fait quoi... je ne comprends pas vince t'as les 9 paramètres ou tu en as moins? il y a plusieurs versions de ces contros, sur certains il y a des menus en moins donc si t'as pas tout , c'est que ça ne correspond pas a ce mode d'emploi t'en aurrais pas que 6 des fois? Lien vers le commentaire Partager sur d’autres sites More sharing options...
VML Posté(e) 9 mai 2007 Auteur Share Posté(e) 9 mai 2007 bah nan 9...le tableau x- __________x- __________x- __________ xx __________xx __________xx __________ Tx __________Tx __________Tx __________ Txx __________Txx __________Txx __________ TTx __________TTx __________TTx __________ TTxx __________TTxx __________TTxx __________ TTTx __________TTTx __________TTTx __________ TTTxx __________TTTxx __________TTTxx __________ xxxx __________xxxx __________xxxx __________ c'est ce que j'entends... j'en déduis 9menus ou alors j'ai rien compris... en fait, j'arrive pas a rentrer dans les sous menu... j'entend rien qui se rapporte au trucs entouré en rouge si c'est pas clair, je ferai une tiote vidéo tout a l'heure Lien vers le commentaire Partager sur d’autres sites More sharing options...
Invité Wilfried27 Posté(e) 9 mai 2007 Share Posté(e) 9 mai 2007 bah nan 9...le tableau x- __________x- __________x- __________ xx __________xx __________xx __________ Tx __________Tx __________Tx __________ Txx __________Txx __________Txx __________ TTx __________TTx __________TTx __________ TTxx __________TTxx __________TTxx __________ TTTx __________TTTx __________TTTx __________ TTTxx __________TTTxx __________TTTxx __________ xxxx __________xxxx __________xxxx __________ c'est ce que j'entends... j'en déduis 9menus ou alors j'ai rien compris... en fait, j'arrive pas a rentrer dans les sous menu... j'entend rien qui se rapporte au trucs entouré en rouge si c'est pas clair, je ferai une tiote vidéo tout a l'heure Oh oui vas y fait nous une video des bip bippppppppppppppppp Lien vers le commentaire Partager sur d’autres sites More sharing options...
