Cozy RC Posté(e) 27 mars 2023 Share Posté(e) 27 mars 2023 Bonjour RC friends, I share my latest build with you. It is a 800mm mono hull, based on the Wild Thing designed by John Finch. I redesigned the bulkheads to accomodate the electric setup better. I scratch build all my boats from wood and laminate. General spec and hardware: Length: 800mm Motor: Rocket 4074 2000kV Speed control: Flycolor 150A Lipo: 6S 4500 - 5200mAh Speed: 100+ km/h Here are some photos: 5 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
gti81 Posté(e) 27 mars 2023 Share Posté(e) 27 mars 2023 Good Job !! 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 27 mars 2023 Auteur Share Posté(e) 27 mars 2023 The bulkheads are from 3mm plywood. The hull bottom is 1.5mm birch ply and the sides and deck are 0.8 and 1.0mm plywood. The transom is 2x 3mm birch plywood. The hull is laminated with 50-110gr/m2 glass. Inside and outside. DIY rudder: And more progress on the hull: 7 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
PHIL94 Posté(e) 27 mars 2023 Share Posté(e) 27 mars 2023 Magnifique! Ton travail du bois est remarquable. Merci pour le partage. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 27 mars 2023 Auteur Share Posté(e) 27 mars 2023 Merci gti81, Phil 👍 Next steps: Maiden voyage video: First run with 43mm 1.4 pitch prop I got 92km/h. Second time with CNHL 90C 6S lipo, the Wild Thing reached 102km/h. I made several build videos. Here's the link if you're interested: I hope to share some of my other builds later. 😀 5 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 10 avril 2023 Auteur Share Posté(e) 10 avril 2023 I'm currently painting the hull. Next I will paint the cockpit window, apply some stickers and apply 2k clear coat. 6 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 15 avril 2023 Auteur Share Posté(e) 15 avril 2023 The Wild Thing is finished. I ran it yesterday at a Dutch RC Powerboat event 😎 3 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 16 avril 2023 Auteur Share Posté(e) 16 avril 2023 I ran the boat last Friday at a RC Powerboats meeting in the Netherlands. No chance for real high speeds, but it is interesting to see how the boat handles choppy water: 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 20 avril 2023 Auteur Share Posté(e) 20 avril 2023 I made a video on how I painted my Wild Thing. I hope you like it 😎 2 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 27 avril 2023 Auteur Share Posté(e) 27 avril 2023 Today I tried a 44mm 1.6 pitch 2 blade prop. The Wild Thing ran a bit loose due to the prop lift. But also fast! A got a new speed record of 114km/h. This pond is definitely getting too small for speed running 😅 4 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 15 mai 2023 Auteur Share Posté(e) 15 mai 2023 This weekend I ran my Wild Thing with trim tabs installed. I also tried a 3 blade 44mm prop. Here's the video of that run, with my comments and speed results: 4 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
NIAGARA Posté(e) 15 mai 2023 Share Posté(e) 15 mai 2023 Salut Jan , du beau boulot bien propre pour un beau resultat ! Les performances sont sympa ! Hi Jan, nice clean work for a nice result! The performances are nice! ++ Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 15 mai 2023 Auteur Share Posté(e) 15 mai 2023 Merci Niagara 👍 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 3 juin 2023 Auteur Share Posté(e) 3 juin 2023 Unfortunately I broke the wooden rudder bracket. I decided to make a new one from aluminium: I also made a wider rudder and different turn fins. Today I tried the new hardware, with great results. I got a new speed record of 116km/h and with a smaller prop I can take corners full throttle. Here's the video of today's run: 7 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 30 juin 2023 Auteur Share Posté(e) 30 juin 2023 Hello RC friends, I did some more speed runs and with a shorter rudder, I got a new speed record at 123km/h. I run a budget setup with a €56 Rocket 4074 2000kV motor and a €53 Flycolor 150A speed controller. I also added an ER8 CNC collet (coupler) between the motor and flex shaft. This reduces the driveline vibration. This is the video of the speed run: https://youtu.be/0pDonFT1258 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jojo76 Posté(e) 30 juin 2023 Share Posté(e) 30 juin 2023 Très bon job pour cette coque bois comme au temps jadis 🤗 de plus elle semble très efficace. À méditer... 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 9 août 2023 Auteur Share Posté(e) 9 août 2023 Unfortunately it's Game Over for my Wild Thing. It got totally wrecked during a crash and dive. It's beyond repair😪 so I took out all the hardware and electronics. Luckily all electronics still work, but the GPS sank.. Here's the latest video with the crash and damage review: 1 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jojo76 Posté(e) 9 août 2023 Share Posté(e) 9 août 2023 🤒🤕😔 Lien vers le commentaire Partager sur d’autres sites More sharing options...
NIAGARA Posté(e) 14 août 2023 Share Posté(e) 14 août 2023 Allez courage , tu peux en refaire une , elle est bien performante ! Go courage, you can make one again, it is well performing ! ++ 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Cozy RC Posté(e) 20 janvier Auteur Share Posté(e) 20 janvier Here's a compilation video, where I cover almost all setups that I tried on the Wildthing. From speed running to oval setups. It might be a good reference if you're running a 800mm mono 😎 https://youtu.be/h7QpCyItGts 3 Lien vers le commentaire Partager sur d’autres sites More sharing options...
